Guys,
1. What is the installed height of the stock Zx14R clutch springs? Brocks mentions 1.04" in the specs for the green springs, is this the stock height spec? Stock seat pressure is 45lb right?
I installed a Brocks Real Street kit but I think its heavier then my needs justify so I am looking to balance the pressures between this level and stock. I bought some EBC +15% springs (in transit) and a spring pressure tester, now I just need some washers/spacers to tinker with. I'm looking at EBC +40-60 thou of shim and see where that comes up at.
2. If shimming a clutch spring do the shims do at the top (like the Brocks thick spacers) or at the bottom like you would for valve springs? I guess washers at the top would be lighter due to the larger ID that they locate against?
Cheers
